4l80e lockup problem
having some problems with my 80e lockup, when i come to a stop after the trans is warmed up its making the converter go into lockup and stall my engine out.
i replaced the lock up solenoid with no luck, i also just put in a new circle d 3200 stall thinking it was my tcs 2800 but im still having the same problem. but with my tcs 2200 stall i did not have this problem, could this maybe be a problem with the trans tune or what? i did a search online for this problem and find lots of info but no ones seems to post what the fix was. any help would be great :hail: |
no one has any ideas? :poke:
Either a sticky valve or a cross leak in either the pump or the valve body is what I would suspect. Just looking in my sonnax book and they have a new valve out to address lockup issues. One of the complaints is TCC apply and release issues do to a worn bore in the valve body. This does require a tool to bore the valve body but it looks like this might be an area for concern with a complaint such as yours. Sonnax Part # 34994-18k. Maybe try to install a different VB to see if it corrects your condition. HTH Vince
Have you put a scanner on it to determine if the ecu is calling for lockup?
Originally Posted by Doc_speeder
(Post 4686733)
i got this info from Chris at Circle D
There is a spring you can install in the pump to help with this. I see it on a few 4L80s, they have low line pressure at idle and the clutch will drag some. I can get you a spring. I have also had a few guys fix this in the tune with the EPC settings. Chris |
Originally Posted by Vince B
(Post 4686752)
Good point but I really feel that the issue is a cross leak or a sticky valve not a programming or electrical issue. Here's the thing according to the oil schematics this trans should not have TCC operation in 1st gear because it uses what they call 2-3 drive oil. This is really what starts all of the fluid for TCC operation. This oil is not present until second gear when the 1-2 shift valve goes to a released position. I feel that the problem is either in the pump or the valve body. Vince
Should of also mention the cross leak as well, like Vince mentioned.
Chris |
(Post 4686715)
Originally Posted by oldred95
(Post 4690918)
My 80 was doing the random lock/unlock and neutraling out at part throttle. I pulled the valve body and had the TCC and AFL valves replaced with upgraded parts, either sonnax or transgo and its worked great ever since.
