4L80E line pressure too high?
Old Feb 21, 2012 | 04:13 PM
1BadAction's Avatar
Registered abuser
Default 4L80E line pressure too high?
Trying to keep this as short/to the point as possible. I have a 91 Suburban with a Gen V 454 big block and a 4L80e. This is the drivetrain original to the truck, although it is possible the transmission is a rebuilt unit. It only has 73 thousand miles. After diagnosing low oil pressure, we found what we believe to be parts of a destroyed thrust bearing (see attached picture).
I have heard about the Turbo 400s and 4L80s producing too much line pressure, pushing the converter into the flexplate/crank causing thrust bearing failure. Now usually it seems like these are rebuilt units in race cars, but I have also seen the same thing happening with RVs and HD trucks pulling heavy loads.
My questions: What is the diagnostic procedure to test the line pressure without a scan tool? Does anyone have the chart with the correct line pressure ranges on it? Lastly, IF the pressure is too high, what do I need to do to fix it so it doesn't destroy my freshly built Big Block? Thanks in advance.
Non-magnetic shavings out of the engines oil pan, from (I think) the thrust bearing. The bottom ends of the rods looked beautiful. Open to suggestions on this, also.
Old Feb 22, 2012 | 12:06 PM
1BadAction's Avatar
Registered abuser
Thanks. I hoping there isn't a problem internal to the transmission. I'll keep this thread updated with what I find.
Ferocity02
Aug 7, 2015 08:50 PM
lxcoupe
Jul 21, 2015 02:12 AM
Ferocity02
Jul 17, 2015 07:05 PM
GMCtrk
Jul 17, 2015 06:39 PM
rojeho
Jul 12, 2015 06:10 PM
