4L80E into a 1500 246 t.case
What is the part number for 80E to 246 coupler and the part number for the 246 input shaft that works with the 80E output?
Has anyone ever ran the 80E output shaft that works with the 1500 246 t.case input?If so where did you buy it? |
I found the 246 input shaft but where do I buy the coupler/adapter to connect the 80E to the 246 t-case?
The 246 and 241 have the same mounting pattern so the same adapter will work. I found mine on ebay.
http://shop.ebay.com/?_from=R40&_trk...All-Categories |
thanks man
where did you find the input shaft at shooter?
tbtrans dot com - thanks to Kysilverado's build thread
yep, bought mine from there too, awesome guy to talk to, very helpful.
I just found a nearly new 4L80 and am wondering what the part# is for that input shaft. Are there any other TC parts required?
You need a new front seal, napa is the only place that has it I believe.
The guy at TB trans gave me the input gear/hub, pilot bearing that goes in it and the seal for a little over $100. I found the tcase adapter on ebay, the seller was justchevytrucks. They didn't have it listed, but I sent them an email with what I needed, they have a ton of stuff.
