4l80e, does this fitting need this O ring?
Old Jun 19, 2010 | 05:06 PM
2005 Silverado's Avatar
SPAM HUNTER
Default 4l80e, does this fitting need this O ring?
I know the picture isnt great but best i can do...only have a camera phone and it is ****
Its the rear fitting for a 4l80e but the oring doent fit the case...can i just use thread tape and some thread putty and call it good.
Does anyone see a problem with this?
Old Jun 19, 2010 | 05:14 PM
kbracing96's Avatar
WOW, thats sum oring,
Mangled03gmc's Avatar
Baltimore Whore
Your not serious. Never seen a O ring like that..
Old Jun 19, 2010 | 05:18 PM
SPAM HUNTER
Got the picture up correct.
NOW what do you think?
Old Jun 19, 2010 | 05:20 PM
kbracing96's Avatar
no, you don't need that oring, just use liquid Teflon and DON'T over tighten it, it will break the case.
Old Jun 19, 2010 | 05:24 PM
SPAM HUNTER
spec is 14-18 lbs i figure sealer and tighten it snug and good to go...now if i can just get that damn pilot bearing out.
Old Jun 19, 2010 | 05:54 PM
kbracing96's Avatar
Use bread it works!
Find something that fits tight in the hole so it will seal pretty well to use as a punch driver that you can hammer on. Then take bread and stuff it in the hole. Keep filling it and packing it in there with your punch tool. The bread will compact and hydraulically push the bearing out. Works better then grease and a LOT less messy,
Old Jun 19, 2010 | 10:50 PM
FLT's Avatar
FLT
FormerVendor
The oring is needed on the factory fitting because there is no sealer used here. On the AN fitting use liquid Teflon as instructed and do not be a gorilla when you tighten it up. There is another fitting out the market that will allow you to use the factory one with the -6 an. Here is a link for you. http://www.purechoicemotorsports.com...rod/prd255.htm
I have also seen a new fitting out from TCI that has the extension tube on it with the -6 AN as well. You will have to look on their site to find that one. Vince
Old Jun 19, 2010 | 11:49 PM
SPAM HUNTER
Originally Posted by kbracing96
Use bread it works!
The grease way didnt work the crank being hollow at the end used up a damn half tube of grease and it was in there GOOD, but its out now
This one came from one of your FLT level 3 80e's wonder why it had the oring?
Old Jun 20, 2010 | 08:31 AM
FLT's Avatar
FLT
FormerVendor
I thought it looked familiar. To be honest I never installed an oring on one of these AN fittings. If I had to guess I probably made the fitting and shipped it to our customer. At which point they must have installed the oring. This was probably before the above advise I gave you was available. Vince
GXPJAY
Feb 13, 2022 08:15 AM
bighouse
Sep 27, 2015 12:37 AM
Abuckeye
Aug 19, 2015 06:11 PM
Jblake
Aug 17, 2015 12:59 PM
tgui
Aug 11, 2015 08:30 AM
