-   GM Drivetrain & Suspension (https://www.performancetrucks.net/forums/gm-drivetrain-suspension-22/)
-   -   4l80e from a 6.5 (https://www.performancetrucks.net/forums/gm-drivetrain-suspension-22/4l80e-6-5-a-509495/)
loganlewis Oct 23, 2012 09:04 AM
4l80e from a 6.5
I located a 4l80e 4wd from a 97 Chevy 1 ton that was behind a 6.5 diesel. I know on hydraulically controlled transmissions the valve body needs to be swapped out because it relys on springs to shift. Since this trans is electronic, should I be able to use this valve body?
I know I am going to lose the top bell housing bolt but there are others who have done an older 4l80 into a newer ls truck. And being that it's a 97 has the correct harness plug and should have a neutral safety switch on the side.
So will that valve body work?
slow67 Oct 23, 2012 10:11 AM
Yes, the valvebodies are the same between diesel and gas.
nonnieselman Oct 23, 2012 11:31 AM
your not gonna have the threaded bolt holes for the PN safety switch.. but yes it bolts up and will run.. just gonna have to build a small bracket for the switch.
loganlewis Oct 23, 2012 11:43 AM
Anyone got any pics for a home made bracket
slow67 Oct 23, 2012 12:30 PM
Just use longer pan bolts, and make an "L" bracket on top of the pan rail.
nonnieselman Oct 23, 2012 01:42 PM
Your gonna have to use your imagination.. ive never seen one built.
1FastBrick Oct 23, 2012 10:36 PM
How about this???
1997 Chevy Suburban 4L80e Transmission Swap Shifter Cable Bracket Photo 7
BTW that bracket shown is a factory GM part that is around $8 through a GM dealer. Other shops are selling it for around $20
GM part number 15013290
It should be the same bracket as your 4L60E if not at least you have the part number.
Vince B Oct 25, 2012 10:20 PM
No need to make a bracket. The 97-98 case has the bosses for the switch.
