4L80 swap questions
Ok, so I picked up a badass 4L80 for a price I couldn't pass up. I have a couple questions...
It's a full manual valve body. I'll need to swap in a trans segment for a manual correct? Who can do this for me? Cross members. I don't want to do any fabbing. I've found one that isn't priced very high that will bolt right in. Are there any factory cross members I could use with out cutting and welding? I don't mind drilling holes. My truck is a 2007 classic 2wd. Are one of these yokes one that I would use with my stock drive shaft? Which one? GM Turbo 400, TH 400 / 4L80E Transmission Slip Yoke | eBay GM Turbo 400, TH 400 / 4L80E Transmission Slip Yoke | eBay Thanks for the help |
Congrats on your 80e, you will enjoy it!
I believe if you have HP tuners you send them your tune and they do the segment swap for you. EFI Live you do it yourself, its not hard and there is a tutorial about it on their website/forum. Not 100% sure on the ebay yokes, but you can also get one from the salvage yard from an 80e truck . You will need a shorter driveshaft. You could get a crossmember from a 99 truck and redrill mounting holes in your frame for an easy crossmember. |
crossmember
If you can find someone with a 07 classic 3/4 ton and measure their crossmember a new one can be had for about $100 plus tax.
Originally Posted by Phantom
(Post 4798330)
It's a manual valve body. The pcm won't control any of that
is it vacuum modulated and does the Manual valve body control the TC lockup? I thought a manual valve body only controlled the shifts, not the pressures and TC locking...
no the manual valve body does not control lockup. that will be done manually.
I'm needing to find out how I can swap in a trans segment from say a 5 or 6 speed vehicle |
sent you a PM.
did you ever figure out which crossmember i was talking about, and i wish you woulda told me you were doin it this soon i gave away my spare crossmember, yoke, and lokar dipstick. i can get more pics of my old crossmember, its on a buddies truck if you need em.
How many quarts of fluid? New converter, stock pan. Pan has been pulled and fluid drained that way. Thanks
