4L65E Trans fluid in round connector
Hello, have a 2003 Silverado 5.3 with a 4L65E. I had the trans built and bigger stall converter years ago. The truck shifted fine when I parked it, no problems. It has sat for almost 2 years. I pulled the engine and transmission and now there is fluid leaking out of the main round connector on top. Is that a sign of overfilled or some seal went bad? Thanks In advance.
Im not sure if it makes a difference but I pulled the engine several months ago and strapped the converted in place, disconnected the trans lines and it sat that way under the truck for a couple months. I didn’t notice fluid leaking from connector then but im not sure.
thanks for the help. This transmission is from a 2002 Silverado. It’s going into a 2003. Everywhere online shows 2 different harnesses for those years. Which should I go with?
snowbunny2
02-09-2011 11:14 PM
