4L65e to 4L80e swap
4L65e to 4L80e swap
Hi guys, greetings from Venezuela, I have a client with a 2006 Silverado reg cab short bed, 5.3 full bolt on cam 243 heads and 4.56 rear end, we use it first with its 4L65e with a performance overhaul kit, first the trans was very good, until we started to have their common problems for not supporting power, we changed to a fully stock 4L80e with its stock converter, we have noticed that its start to deteriorated much as much as a 2008 Silverado only tune starts at its side until 2006 makes its first change and what about, it is worth noting that 2006 is running with hoops 22¨.
My question is: Is this normal for changing to this trans? I understand that the first speed of the 80e is longer, what would I have to do to improve the start?
I await your opinions and your experiences, thanks
[QUOTE = 2002_Z28_Six_Speed; 5457027] Creo que está hablando de que el 4L80E tenga una primera marcha más alta y que el cliente tenga ruedas muy grandes. Yo pensaría que un 4.56 sería suficiente engranaje. Aunque nunca he corrido grandes llantas antes. Tal vez ir a ruedas más pequeñas y livianas sea la solución correcta. [/ QUOTE]
Excuse me if you do not understand my English well, sometimes I use the translator, many times it does not work well,
What I mean is, I've noticed a lot of deterioration in the launch on this truck since we changed from 4L65 to 4L80, the truck since we had the 4L65 had already installed a 4.56 gear, then we installed the 4L80 and it started everything, the 4L80 behaves very well does not give symptoms of some wear or something, changes firmly, I only notice that the engine costs more to accelerate, as I understand your stock converter is very large and is not made for performance, there are those who say that be the problem, here is where I consult in this forum
With a cam the converter will make all the difference in the world!
Yes sir my pleasure. It's going to be a different beast altogether with a looser converter. Good luck!
once i saw that it was through a translator, I was able to make more sense of it. for example when you say it "changes firmly" I was able to understand that meant "shifted firmly"
Anywho...I think a performance converter will make a huge difference for your truck. I don not think anything more than a 4.56 is needed
