4L60e Swap question
I think there are internal wiring harness and parts differences. IIRC, they made changes to the transmission in 06. might have been 05. Call up your local trans shop and double check. Biggest thing I can think of is, the electrical connections might be different. 08 is GMT900 and 05 is GMT800.
MikeManer (04-05-2017)
jik294, thank you for the reply. I did find some additional information that confirmed your comment. It appears from what I read that my valve body and wiring harness can be swapped into the 2008 model. If anyone else has experience with this swap I would really appreciate your help. Thanks again jik294
Mike
Mike
Yes you can swap it no problem..all the 07/08 models have extra is the input speed sensor..witch your model doesnt use so doesnt affect it..if you do it vice versa swap in a 99-06 model in a 07-08 the check engine light will come on as it doesnt have the signal from the input speed sensor
