Good or Bad to bypass trans cooler in radiator??
It seems like I have been researching transmission upgrades & transmission cooling to death, while I wait for my transmission repair/converter repair. I have read about people bypassing the stock cooler in the radiator and only using the Tru-Kool 40k. Apparently, that might actually be bad idea.
Transmission Cooling: You must have a transmission cooler in your radiator regardless of what someone has told you for the transmission to last. Auxiliary coolers are just that, in addition to. Water cools 32 times better (faster) than air always, period. The transmission fluid comes directly from the torque converter at a much higher temperature than the water in your radiator and is cooled to the water temperature fast. Then it goes to the auxiliary cooler to be cooled far below the water temperature. If you don't need a cooler in your radiator why does GM spend all that money doing so? If you wanted to cool a red hot piece of steel fast would you stick it in water or air, see the point. For the best cooling you need both water and air cooling for the transmission to be cooler than the motor.
Makes sense to me....... What do you think?
2nd fastest 5.3 ECSB
Please include link to that statemnt.
Honestly I have never heard anyone complain of failures either way... it's the fluid temperature that counts so if it's cool enough it's good, either way.
Sharty_McQueef (08-09-2022)
It seems like I have been researching transmission upgrades & transmission cooling to death, while I wait for my transmission repair/converter repair. I have read about people bypassing the stock cooler in the radiator and only using the Tru-Kool 40k. Apparently, that might actually be a bad idea.
That is the most absurd and ridiculous article on the matter that I have ever read. GM runs it that way from the factory because it is actually cheaper for them to do it that way and it uses the heat from the radiator to get the fluid up to temperature when you first start driving.
This is an economical solution for GM and works well for the average user. However, a cooler like a tru-cool 40k bypassing the radiator is superior in every way. Once it gets up to temperature it is not fighting against the heat the radiator is putting out and soaking into the transmission fluid. With the stock radiator cooler in town traffic would push my temperatures up to 250. With the tru-cool I never break 165. Now explain to me which is more efficient? Transmission temperatures don't lie.
Just because GM does something a particular way does not mean it is the best way. It just happens to work well enough for the average user and that is all GM is concerned about.
I hope that anyone else that posts in this thread or others on this type of subject clarify if they live in TX, FL or warmer climates. I mean if you're like me, & don't have that in your avatar.
On a DD in northern areas, it's important to those people. As to if they route thru rad or skip it. Also, on a cold weather bypass, if left out, I kinda figure they live where it 's warmer. I left my bypass off, BTW. I don't think I'll have any problem, but if I do, I have it & I'm gonna give that person a ...
Proof of they cater to avg. consumer? Remember the RCSB SS w/. a 6 spd., roll up windows & rubber floor GM came out w/.? ME NEITHER!!!
