4l60E with converter
You can get a 3000-3200 thats rated to tow with.
Ive used this in several trucks with cams and they tow car haulers.
The tune needs to be setup correctly.
https://www.summitracing.com/parts/fti-sb3200ls
https://www.summitracing.com/parts/fti-sb3000ls
Cool. I had no ideal that a converter like that could tow 5000 pounds.
Can you elaborate a little b it on setup ?
Presume you Lock 3rd gear early, and STAY locked late for Tow-Haul mode ?
How about overdrive ? What shift speed-split/ vs lockup strategy do you use to mitigate monster rpm FLARE when unlocking in OD ?
Datalog TCC slip and program accordingly.
Not necessarily locking the TCC early. Just not trying to lock the converter when its at max slip then bogging engine.
Its a fine balance and takes a little while to get it just right.
Id rather downshift to 3rd and lock instead of unlocked 4th.
dirt track racer 81
Oct 28, 2006 02:42 AM
