4.11s
#31
Man i sure didnt cause i took the cage off it and threw it away. That makes alot of sense tho. Honestly think that might be the problem. I know the outer bearings are the same but not sure about the inner bearing. I think they were but not 100% sure. The kit that came with it is a motive. The bearings say koyo on the bottom. I didnt know bearings were different sizes tho. That explains alot guys..what bearing do yall recommend. And the shim under the inner bearing is the stock one i pulled off the old pinion
#35
New bearings always need the new races. I would replace both races and bearings at this point. Get a brass punch/drift and drive them out. Use the brass punch to drive them back in, don't waste your time with bearing drivers
Also, put the races in the freezer for days before the install and it will help
#38
