2003 Z71 4l60E problems
Old Feb 1, 2007 | 10:46 PM
GarnerZ's Avatar
Default 2003 Z71 4l60E problems
i have a diablo predator programmer. when i take the diablo tune off and go to the factory tune i get a late , slow, harsh, shift from 1st to 2nd. this is a normal take off
when i put the diablo tune in it goes away.
also when i have the factory tune on the transmission does not seem any thing like it did when i first got the truck. it feels like it is sluggish, crazy shifts, does not want to downshift sometimes
another thing is the transmission starts off in 2nd gear sometimes. this is not a all the time thing. once in a while it will do it.
ive searched and nobody seems to have had these problems
any ideas, fixes....
2003 ext cab, 5.3, 4l60E, 40,000 miles
Old Feb 2, 2007 | 02:29 AM
GarnerZ's Avatar
could be
Old Feb 17, 2007 | 08:29 PM
Wide Open's Avatar
I had the problem with my transmission starting out in 2nd sometimes. I don't know the cause and since I just blew my transmission I never will. I didn't have any of the other issues you descibed though.
Old Feb 18, 2007 | 07:23 AM
FLT's Avatar
FLT
FormerVendor
Do to the fact that you are having a 1-2 shift problem and also second gear starts at times. I would be looking at the 1-2 accumulator circuit. It is possible that you have a cracked 1-2 accumulator piston. Along with that you could have a broken spring in there. With the factory tune the line pressure could be lower and this condition might be more noticeable. Bad part is that your 2-4 band is probably hurt.
Old Feb 19, 2007 | 03:12 PM
TX Tahoe Z71's Avatar
I had a similar problem, mine didn't want to upshift to 3rd until above 2500 or 3000rpms. Turned out I burned up some of the syncros due to removal of tq mgmt from tuning. But it was covered under warranty.
ferrellrooster
Mar 6, 2025 03:22 PM
CD82
Sep 29, 2015 05:45 PM
Tigger Welder
Sep 2, 2015 08:17 AM
Abuckeye
Aug 19, 2015 06:11 PM
stock48
11
Aug 18, 2015 05:55 AM
