2003 silverado 2wd open or limited slip diff??
Hi everyone,
I have a 2003 Silverado 2wd with 114,000 and I wanted to change my diff fluid but I needed to know what kind I had, it's a 10 bolt diff and my only code I haveis GU6 no G80 code, does that mean it's an open diff??
Also, if it is open, just about every fluid now a days has limited slip friction modifier added, is it okay to use it in an open diff? Like royal purple for instance? Thanks!
If its an open diff it doesn't matter as there are no clutches as in a limited slip that has clutches or gears. Pull the cover if you can . If you have just spider gears then its open. If you have spider gears with springs and other goodies its a LSD. If its like mine its just an open diff. I threw Mobil one in and left it alone. No additives
If its an open diff it doesn't matter as there are no clutches as in a limited slip that has clutches or gears. Pull the cover if you can . If you have just spider gears then it open. If you have spider gears with springs and other goodies its a LSD. If its like mine its just an open diff. I threw Mobil one in and left it alone. No additives
Sweet great to know! Im probably going to run royal purple either way though
I did mine just this past week, I used Mobil 1 75-90, 3 bottles, and went ahead and changed the cover and gasket could of used maybe a little more but I work at Valvoline so I just grabbed a little from the shop, doesn't really matter if it has LS additives. Just put a synthetic in the diff, and don't do drain and fill take the cover off and clean the magnet or else all the metal shavings and gunk will contaminate the new oil. remember check the bolts after 100 miles and make sure they're snug.
Also just a personal thing I wouldn't use royal purple man, don't trust the stuff, heard some pretty bad stories from friends and have seen it destroy a diff before, maybe it wasn't the oil maybe it was.. all I use is Mobil 1 in all my cars and I work for Valvoline for crying out loud! But that's just me
good luck!
good luck!
good luck!
good luck!
Oh yea I was definitely going to take the cover off to clean the magnet, I'm going on a hunch the original owner never even touched it so Im going to replace the gasket and everything, buti didn't know that about royal purple gear oil.. how about amsoil? Or just go with something cheap?
