2000 freakin miles... damn the 60E!
Old Jun 29, 2011 | 04:24 AM
TIM Z's Avatar
11 sec. Truck Mod
Lenco FTW John !!!
That sucks for ya sleeper, i also felt your pain.
We need to have a broken 60e club, i'd have 4 stars! LOL
Old Jun 29, 2011 | 08:02 AM
sleeperlqx's Avatar
Well here is the news, I am applying the warranties! The ase trans mechanic will rebuild the 60e to a built unit, and Im going to put it up for sale after its back to perfect condition. Im going to get converter switched out under warranty as well so I can throw a 36-3800 stall behind the 80e. My other mechanic is going to pull the tranny today to take it to my trans shop. Im looking for a small diameter stall but I will see what Frank with the converters recommends.
Where do I find a cross-member at that will support my same driveshaft?
Old Jun 29, 2011 | 08:30 AM
silver-mod-o's Avatar
Hunt&Fisherator
dont feel bad... I broke two in two days... BY MYSELF, in the same truck
Old Jun 29, 2011 | 12:02 PM
JFOLM's Avatar
Is that a record?
Old Jun 29, 2011 | 02:03 PM
sleeperlqx's Avatar
ok, well here are the updates...
Got a 4l80e trans picked up with 30K miles on it, going to have my trans guy go through it, and upgrade to a hd-2 shift kit, install my 3700 stall converter. Then go get my pcm reflashed by my tuner Alvin.
After I bought the tranny, I went straight to the converter company, and they were pretty standup. So the new converter will be a billet and stage 5, and stall about 3700 rpm with a 9.5 diameter, Minus the difference of my 60e stall price.
All I need to do now, is get the harness ends, or repin a harness to work the 80e, and add the extra VSS sensor.
I also need a crossmember that will support my current 1 piece shaft.
Also I yoke that is long for the 80e is what I read.
But hey guys, if you have some good helpful links for me, please can you post them to this thread.
Here is what my new converter will look like.
Ill post pics of the 80e shortly.
Old Jun 29, 2011 | 03:02 PM
Exclamation
Holy Crap! What a converter! That thing looks like it can withstand a few thousand HP! What brand is that and how much was it?
Jim
Old Jun 29, 2011 | 03:43 PM
sleeperlqx's Avatar
its a REVMAX converter, google it, every time I post a link about the company its removed cause they are not a sponsor on PT. But ask any diesel guy they will tell you what a hell of a converter they offer. Even stall speeds lower than factory!! But nuff rant.
Its a level 5 Im getting here are the specs, google them.
* Extreme Street/Strip 9.5″ 245MM Torque Converter
* Customized Stall Speed, available from 2500-5000
* Performance Rated up to 850HP *Lockup Units*
* Custom Built To Your Vehicles Excat Specifications
* Anti Balloon Plates
* Mechanical Diode Sprage Assembly Upgrade Available
* Steel Stator Assembly Upgrade Available
* 4130 Chrome Moly Flanged Impeller Hub
* SOLID ONE PIECE CNC BILLET FRONT COVER ASSEMBLY
* Custom Billet Dampner Piston Assembly
* Extra Wide High Performance Lockup Clutch Friction
* Available with Triple Disc Lockup Clutch
* 4340 Hardened Turbine Hub and Splines
* Completely Tig Welded Reinforced Impeller
* Tig Welded Reinforced Turbine
* Torrington High Performance Stator Bearings
* Torrington High Performance Turbine Bearings
* High Performance Max STR Torque Stator Sprag Assembly
* Computerized Robotic Sealing Welds
* TCRS Computerized High Speed Balancing to less than 5 grams
* Nearly 12lbs light than a factory 12″ Converter
* Runout Tolerances of less than .005
Old Jun 29, 2011 | 05:48 PM
sleeperlqx's Avatar
its home, just lifted the 4L80e off of the truck.
and the converter it came with
ill be replacing that^^ with this bellow
that son of a bitch tranny is heavy, this one has 30K miles on it. Im going to have my ASE trans guy put a transgo hd2 kit on it, and see what it does with my 3700 stall converter that is 9.5 diameter.
Got to find me a cross-member and get the wiring together with correct yokes.
Old Jun 29, 2011 | 05:58 PM
smokeshow's Avatar
Mod with training wheels
This kinda **** needs to stop, it is making really fukn skidish now about my lvl2 p built.. Hell even threads up on 80's acting up.. Stop stop this nonsense now.. It has done very very well the past 2 years.. I hope the trans gremlins stay out of my trany...
My 60e was fully built...everything that could have been done to it was done. What killed it was an extreme amount of load. I was brake stalling at the track and the input sprag bit the dust. Being lighter is a HUGE advantage when it comes to transmissions. Brake stalling like that was probably the equivalent of me towing a 10k lb trailer up a hill in 1st at full boost, converter unlocked. They can take a lot of torque, but not a lot in the weight department.
And if you're talking about my 80, it turned out to be just fine. Just some metal shards in it from the converter. Clutches got replaced though!
Old Jun 30, 2011 | 01:13 AM
swift700's Avatar
You'll love the 80E. I like mine as much as my new engine. It instills confidence and shifts so quickly. It is a must have item and is pretty easy to swap.
