-   GM Drivetrain & Suspension (https://www.performancetrucks.net/forums/gm-drivetrain-suspension-22/)
-   -   2 piece driveshaft build (https://www.performancetrucks.net/forums/gm-drivetrain-suspension-22/2-piece-driveshaft-build-512060/)
blackedoutchevy22 Dec 22, 2012 05:37 PM
http://i47.tinypic.com/v66o81.jpg
http://i48.tinypic.com/mlry2q.jpg
http://i45.tinypic.com/vfbz7.jpg
http://i49.tinypic.com/35k72vb.jpg
http://i50.tinypic.com/f3gchc.jpg
http://i47.tinypic.com/6rlf5w.jpg
01FormulaTA Mar 19, 2014 06:54 PM
Can you provide measurements on the cross member that was fabbed up?
Thanks
00Silv4.8 Mar 19, 2014 09:48 PM
and did you make your own driveshaft? if so are you concerned with balance?
AUTOT3K Mar 19, 2014 10:22 PM
I basically copied this exact design, it was really easy to do
slide under your truck, find a spot between the diff and transmission where you can easily mount a x member. mine was roughly 36" back, just ahead of the fuel tank/evap stuff, measure frame to frame and go grab the supplies you need!
call up DSS in Houston and order away!
badz24s Mar 23, 2014 03:57 PM
Make me one for my 07 nbs crew. U gotta truckshop tune so that means u aint far from me
