-   GM Drivetrain & Suspension (https://www.performancetrucks.net/forums/gm-drivetrain-suspension-22/)
-   -   2/4 belltech drop CC VIBRATIONS (https://www.performancetrucks.net/forums/gm-drivetrain-suspension-22/2-4-belltech-drop-cc-vibrations-504861/)
GSXRDAVE21 Jul 16, 2012 09:15 PM
So i did a 2in spindle and a flipkit on the rear for 4in drop now i feel vibrations @ 65mph talked to belltech tech support and they say their kit does not need rear shims and the pinion angle should be right what do you guys think 2012 chevy cc 4x4 one piece drive shaft. thanks
Area47 Jul 16, 2012 09:31 PM
check the pinion angle at the trans and diff
GSXRDAVE21 Jul 17, 2012 09:42 PM
what should the angles be at?
LS1TRUCKGUY Jul 17, 2012 11:36 PM
Somewhere in the neighborhood of-2 degrees on the rear end should get you close...
LS1TRUCKGUY Jul 17, 2012 11:37 PM
I helped a buddy instsll a beltech 2/4 drop and his needed 4 degree shims
