14 Bolt 9.5 Axn Yoke?
All help is appreciated.
I want to build a driveshaft for my 14 Bolt AXN conversion, I know it is a 1350 and have been told to use a 1350 like the ones on the 10 bolts. Can anyone please guide me to the correct yoke with correct spline count? A link to a specific yoke would be great because I see a few with different lengths: Yokes - Differential Yoke Location - GM 8.5 in. Axle Model - Rear Axle Location - Search Results for 1350 yoke - SummitRacing.com Thanks a lot |
GM# 26060881 should be a 1350 diff yoke for the 14bolt. Comes with a new seal and a pinion nut.
Edit: Looks like Robert91RS is right.
I believe the 8.625 uses the same size 30 spline but the 8.625 factory version has a smaller sized u- joint. |
Thanks a lot guys for the part numbers. Now I know I can't go wrong.
Thanks again |
