1 piece drive shaft
1 piece drive shaft
i have a 2001 silverado 1500 2wd ecsb and since i put a bell tech 2/4 drop on it i have drive line vibration. is there somewhere i can buy 1 piece aluminum shaft so i can get rid of this 2 peice
i have been searching on here and found multiple threads started on this same topic but can't find one where anybody has actually done the swap or said where a 1 piece could be purchased.
i really think a 1-piece aluminum shaft from a 2005 crew cab 2wd will work just trying to see if anybody has done it
If your plan is to get a 408/4L80e have someone build a 3in thick walled steel driveshaft for you.
Don't even consider a stock driveshaft from a factory truck, they are not rated for high speeds and a built driveshaft made to handle more power is the right way to go.
idahoblkss
10-18-2016 02:38 PM
