07 4L60E Mods
07 4L60E Mods
Hey guys, new to the forums here, was recomended by a guy at the dealership I purchased my truck at.
I have been reading on this subject for mods for awhile now and still am undecided. I just purcahsed the truck recently. The truck is a 07 NBS 5.3 Extended Cab LTZ 4x4 with 99000 miles. I will be using for my daily and towing, maybe 4000-5000lbs. every now and then. I would like to do whatever I can to upgrade the 4l60e for longevity and towing. Trans works perfect and has no issues what so ever. I would like to do any mods possible without removing the trans from the vehicle. The truck already has a trans cooler added from the factory.
My local dealership gave me recomendations and what i should do.
-Mag-Hytec Deep trans pan
-Corvette 2-4 Servo
-Sonnax 4th/OD Billet Servo
-TransGo-HD2 Kit
-TransGo Seperator Plate 46-PLT-07
-Billet Forward Accumulator Piston
Is there anything you can add/change to this guys. Im not looking for a hard shifting street/strip truck. just daily/towing.
-Corvette 2-4 Servo
-TransGo-HD2 Kit
60k mile 4l60e with vette servo, 40k cooler, 3200 stall and tune.
Many many highyway races and mild abuse. Probably had 200+ lbs of nitrous run thru it.
Still ticking. Its hit or miss on how long they last
based on what you want, don't use any of the shims in the Transgo kit. I did 2 shims and it was a pretty snappy 1-2.
definitely add a bigger cooler if you're doing it for towing.
If you're doing one accumulator, do both. I did Sonnax pinless accumulators in the tranny I have now. a little tricky to figure out but it works.
My new era tune and vette servo is nasty. I would not want it to shift any harder than it does now. I go wot everyday and 4wd launches all the time.
So far mine is fine but I just ordered a built trans because I want another 100 more wheel and do not wanna be stranded somewhere if it let goes.
Give it a full flush too
Thanks for all the info guys. so far i have updated list of parts. let me know what you think.
-Tru-Cool 40k Cooler
-Corvette 2-4 Servo
-TransGo-HD2 Kit
-GM OEM 1-2 Aluminum Accumulator Piston
-Sonnax Pinless 3-4 Accumulator Piston
-Sonnax 4th/OD Billet Servo 77767k
-Sonnax Billet Forward Accumulator Piston 77998-03k
-Sonnax Torlon Check ***** .250 x10 10000-08
-And a tune to remove 75% Torque Management/100% in TowHaul mode
-Corvette 2-4 Servo
-TransGo-HD2 Kit
GM1697
09-09-2015 01:52 PM
