Are 2.02 valves overkill
I recently got a pair of 799 heads ported and polished with a valve job and upgraded to 2.02 valves. Are the 2.02 valves overkill on my 5.3? Currently has flat tops, 3,800 stall, nnbs intake, 4.30 gears, 233/239 cam .63x .62x @112
Maybe.
On a small bore 5.3, to large of a valve can hurt airflow into the cylinders, thus robbing it of power. I believe the term is 'shrouding'.
On a 6.0, where the bore is 4.0, it would probably benefit.
Same reason some people argue that ls3 heads on a 6.0 aren't beneficial.
Yeah that too, but did an overhaul and did everything I could to this 5.3 so a bigger motor will have to wait. Should've gone 6.0 but live and learn I guess
