Who is using PTFE lined braided lines for fuel lines??
Just curious who is using these lines rather than normal rubber/rubber synthetic lines.
>>>>This Guy<<<< only downside is you can't make sharp bends or you'll kink the liner. Made the swap after one of my lines began to leak.
I use them for clutch lines and turbo oil feed, so far so good! But as mentioned, PTFE doesn't like sharp bends.
All my stuff is PTFE.
My opinion is that it is the only way to go (aside from bending up hard lines).
We actually build them here, and the burst pressure is ridiculous. All of my Nitrous, Fuel, Brakes, Oil.....everything gets the teflon treatment. |
same here used it on everything.
Originally Posted by bfurches
(Post 5035006)
all my power steering lines on my samurai are PTFE lined. Said heat doesnt bother it much at all.
