-   FUEL SYSTEMS (https://www.performancetrucks.net/forums/fuel-systems-210/)
-   -   walbro issue (https://www.performancetrucks.net/forums/fuel-systems-210/walbro-issue-518807/)
hsiriyob Jun 11, 2013 07:06 PM
walbro issue
I installed a 255 walbro ss340 last weekend into my 2004 silverado. Install went well and it fired right up and ran great. I went on a cruise today and the truck started acting like it was running out of fuel. I put ten gallons in and it is doing the same thing. Ill check fuel pressure off my rail tomorrow when i get the tool, but does anyone know of this issue with this pump? I have also heard that it could be a relay? the pump primes so its getting power. Figures after all that work a cheap pump would fail :sigh:
Chevy_King1500 Jun 11, 2013 07:47 PM
did you replace the hose from the pump to the top of the tank? check fuel pressure and report back
hsiriyob Jun 11, 2013 09:58 PM
yes. Im pretty sure its the way i mounted the pump. I believe it jumped up higher than the fuel level and over heated. ill check pressure tomorrow.
hsiriyob Jun 13, 2013 05:30 PM
checked fuel pressure today and im not even getting 1 psi. decompressed the valve and no fuel at all. assuming its the pump im going aeromotive 340.
Chevy_King1500 Jun 13, 2013 05:38 PM
what kind of hose did you use to replace the old one? if its not "submersible fuel line" it may have swollen shut..
2toneblown Jun 13, 2013 06:13 PM
I would bet its the hose in the tank as well
hsiriyob Jun 13, 2013 07:18 PM
2 Attachment(s)
Originally Posted by Chevy_King1500 (Post 5114001)
why kind of hose did you use to replace the old one? if its not "submersible fuel line" it may have swollen shut..
I believe it was 5/16th gates hose. If its not Can it swell close after 2 days? Ill check it this weekend after i get the bed off. here are some pics of the hose i used. Is this fuel submersible?
Attachment 114633
Attachment 114634
hsiriyob Jun 13, 2013 07:30 PM
dropped some of the hose in some gas ill look at it in the morning and report back.
Chevy_King1500 Jun 13, 2013 07:33 PM
i doubt thats the right hose, the hose comes in a plastic bag pre-cut.. i had the same thing happen to me, it sucks, i know.
i would just re-use the factory plastic one, take your time and get it right, the second time i had to pull the bed i got pissed and got in a rush.
needless to say i had to pull the bed a third time because a wire was holding the float down and causing a "low fuel" light..
just speaking from my experience/mistakes
hsiriyob Jun 13, 2013 08:03 PM
I asked for gates hose at autozone and asked if it was fuel submersible. Last time I trust an "expert". Glad to know I'm not the only one messing up. Ill look at napa for the right hose.
