Walbro 450 In Tank Install
This is my first attempt at doing a Walbro 450 in a stock nnbs felx fuel bucket. I would like to get some opinions and feedback on what everyone thinks of it and if anything needs to be changed before install it in the truck. i used gates 5/16 hose from the pump with AN fittings stepping up to 8AN at the bulkhead. Using the stock feed line as my return line also.
http://i61.tinypic.com/o74jus.jpg http://i58.tinypic.com/2pob0at.jpg http://i58.tinypic.com/1zf1vmt.jpg http://i57.tinypic.com/wqyk37.jpg http://i57.tinypic.com/r7kcqd.jpg http://i61.tinypic.com/1zel893.jpg http://i57.tinypic.com/2ithdmc.jpg http://i59.tinypic.com/xlzg94.jpg |
Did you make that little plate in the bottom of the bucket? Thats pretty cool.
I would recommend some clamps on top or behind the barbs for the rubber hose. |
Cool. This works for the guys running an external FPR. I went ahead and put one in my nonflex bucket and kept the factory regulator about a month ago and it works great
Yeah I made that plate to fix the pump in the bucket and I have some crimo style clamps on order waiting for them to come in
Originally Posted by Atomic
(Post 5320153)
What is the part number for the bulk head you/others are using?
This is the part I used from xrp (-8 AN 90 bulk head fitting (983308BB))
I also reduced down to -6 AN push on fitting for the 5/16 ates
Do you end up doing away with the venturi?
