Walbro 450 stock wiring harnesses
Old 02-09-2018, 10:51 AM
Kws82590's Avatar
Default Walbro 450 stock wiring harnesses
upgrading the fuel system on my boosted 2012 GMC Sierra 1500 5.3 and was wondering if anyone has used the stock fuel pump wiring harnesses to run a single walbro 450 and if not how are your wiring
Old 02-09-2018, 11:17 AM
11 Second Club
MrHorsepowerLSx's Avatar
Buy a hot wire kit and save your truck from burning to the ground. The factory wiring cannot reliably support the additional amperage/voltage draw from the larger pump. Also the hot wire kit gets hooked directly to the alternator so the fuel pump will receive whatever voltage the alternator is putting out as opposed to whatever the battery/pcm are sending to the pump
Old 02-09-2018, 01:25 PM
Kws82590's Avatar
any chance you have a link
Old 02-09-2018, 03:43 PM
11 Second Club
Racetronix - Hotwire / Power Upgrade
Start here, you may have to research around the site tho on exactly what people are doing for wiring upgrades on NNBS trucks
Old 02-09-2018, 04:08 PM
Kws82590's Avatar
awsome thanks for the help
Old 02-11-2018, 09:18 AM
10 Second Truck Club
RS/SS 4.8's Avatar
I had the 450 run by the stock fpcm on my 07. Now i used a relay off the old fpcm wiring. No hot wire here since the wirings already 10g.
Old 02-12-2018, 07:33 AM
crutt's Avatar
I'm running mine through the FPCM using the stock wires
Old 02-12-2018, 08:16 AM
Kws82590's Avatar
yeah i just ended up wiring in a relay to the FPCM
Old 02-12-2018, 12:24 PM
crutt's Avatar
I might still run the hotwire kit, I just don't want to have to retune right away
Old 02-12-2018, 03:31 PM
11 Second Club
Why need to retune for an electrical upgrade
M60gov20 (02-12-2018)
Quick Reply: Walbro 450 stock wiring harnesses
