TECHRON, Marvel Mystery Oil, etc... Benefit or BS
Old timers always ran " Top Oil " in the ancient long stroke, side valve engines.
Piston aircraft operators are STILL using Marvel Mystery Oil , buying it by the gallon.
Is there any benefit to adding half a pint of Snake Oil to the fuel tank in a modern, fuel injected automobile ?
I use TECHRON in all of my modern vehicles, full bottle each oil change.
We have no ' name brand" detergent gasoline nearby, so I use the TECHRON to keep the fuel injectors clear... Am I wasting my money ?
. Can I buy the magic ingredient in TECHRON cheaper by the 5 gallon pail ?
Custm2500's Rude Friend
Chevron gas with Techron additive is good stuff. You will see the difference when you disassemble an engine.
Pure TECHRON is not available by itself unless you work at a chevron refinery and can sneak it out the door...
That being said techron injector cleaner you are buying has a small amount of pure techron in it. I am not sure how much or how efficent it is though.
I have been using Berrymans B-12 additive once every oil change as it its cheaper than Seafoam and seems to have a similar effectiveness.
BG is top quality stuff though generally the shops that use it are buying it in larger quantities and have a fixture called VIA that allows them to pump it directly through the fuel rail for a thorough cleaning. They have a separate product intended for cleaning fuel injected vehicles, instead of "BG 44K" it's "BG Fuel Injection System Cleaner" - their application notes that you use the FI cleaner first, delivered through their VIA tool, to pre-soften crusty deposits before you use BG 44K. I suspect this two-chemical approach is what you would have to do with the crazy deposits these direct injection engines are getting now.
You can score BG 44K from Amazon, $19 a can shipped, with Prime. About what I used to pay years ago walking into a Carquest, so at least the price hasn't gone stupid with inflation. Or score a 6 pack for $82 which works out to just under $14/can, nice savings.
Sorry to sound like a BG commercial. I love their stuff! Grab some and dump it into your tank with a funnel.
Richard
Every other oil change I pour a can of SeaFoam in my crankcase about 30min before the oil is changed.
I run a few errands, get in it hard a few times, drain it and fill it up.
When I did my cam swap last month, the top of the heads looked brand new.
When I changed my oil pan gasket last year, the windage tray looked new.
BG 44K can be tough to find locally but I wonder if it's tougher for you because you're in California. Here in Texas, you used to be able to just walk into a Carquest or other "decent" parts house (mind you before Carquest was bought out by Advance) and buy the old school peel-top cans with no issue. A few years later I had to seek out a shop that carried the stuff, and could buy it from them, but in bottles. That shop is gone now, though.
Richard
Richard
I Believe it's just because they tried to be a professional use only type product and they push it in shops and dealers. Occasionally I see a Van in my area making his rounds.
I believe at 1 point it was available through some parts stores here as well. But as the bigger companies come in and take over they only sell who ever gives them the best deal with the largest profit margins...
