TBSS intake
well I just learned a Tune is not 100% needed unless you swap the injectors. You will however need an X-Link if you plan on goin to the 87-90MM TB. Or you can keep your stock TB and buy an adaptor plate as stated above. Now your tune will not be %100 spot on but it will still run good. As for the fuel rails you shouldn't need anything special as long as you keep the TBSS fuel rails. Your fuel system should be a returnless style. You will have to extend MAP sensor harness some also stated above. I may have over looked something so If you have any other questions just let me know. Good luck
ALL ULL C
05-30-2018 10:14 AM
hirdlej
05-31-2009 09:46 AM
