Switching to E85 on NNBS
Fuel system question. Running a ZL1 blower with heads and cam. Running 10 psi now making 530 on pump gas will be on 15PSI soon. I have 90 pound DW injectors at the moment and wanting to switch to e85. With 90s be enough injector and what intank pump do you guys suggest on running? Single 450 or dual? The truck is already a flex fuel truck. Just need help deciding where to go with the fueling I would rather over kill it because it will be making more power down the road.
magnafuel just released the 4303 in-tank fuel pump setup!! That would be all the fuel pump you would need for sure!
https://www.motionraceworks.com/stor...uelMP-4303-BLK
I would just use the injectors you have and see where they getcha. Surely you can be in the 650hp to the tire range with the ones you’ve got now.
