On3 fuel regulator and return kit
Anyone have any experience with this setup? Good? Bad? I need to add a regulator and return line after tbss intake swap. Vette filter wont hold the pressure below 70psi.
https://www.on3performance.com/shop/...ystem-upgrade/
I have a gauge for that
Eh, its a cheap kit that would probably work fine to the 500-600 range, but if I was doing more than that I would get real rails with a name brand regulator. It is using the test port on the rails as the bleed which is not the main function and does not flow a lot. You would need to be deliberate on when you have the second pump kick on if running dual pumps.
I was afraid of that. Just a good regulator is the price of this complete kit.
marovetsm
08-11-2013 09:15 PM
denali_on_26's
11-04-2010 07:09 PM
