Nnbs return fuel system wiring fpcm
You just lay it in the bottom no secured? Did you run bigger gauge wire for the pump? Wonder how much amp is draws. Nobody had a cure to the Venturi problem or has success? How do the hellcats and performance high power cars do it then?
Hellcat draws abor 25 amps At 60 psi. With radium engineering Venturi it can suck more fuel into the bucket keeping it full and co the pump. Many people can just lay it in the tank and go race on the weekend. My truck is a daily driver and I don’t want heat to destroy the life of the pump. The stock Venturi worked but it was too small to suck enough fuel into the bucket when the tank was less than 1/4 to 1/8 full and at WOT the performance pump drained the bucket and the Venturi couldn’t keep up. I’m sure others have done without the Venturi and they have no issues or have just laid the pump in the tank with no issues.
Man that seems like a little high amperage for stock #12 wire.. my truck will be a weekend truck but I tow with it and use it for raid trips so it needs to be daily drivable Incase I need the truck. Can you send me a link to the new Venturi your buying? It just replaces the stock one just bigger? I don’t really plan on going wot pulls on 1/8th of a tank. This truck probably will never see the track to be honest
Venturi Jet Pump Kit that’s the Venturi, I checked with aeromotive and they recommended using it on the feed side per radius instructions. They also said there will be a decrease in flow from the pump of course as some is being diverted to the Venturi but negligible and benefits outweigh costs. The amperage draw is why I upgraded the wiring. as psi increases amp draw increases, not having right size wire will not allow the pump to operate at full potential.
Tell that to the guy above lol but I’m still interested in pics of you build to get an idea of what mine will be like. You have the 5.3 crew cab 4x4 Sierra? What trans you running?
Post pics on here for all to see.
The thread i was looking into got closed for some reason.
I was wanting to tap into the FPCM, but since then, i dont think that will be an option anymore.
Im doing duals though, with a Hobbs switch, any help is appreciated
