Need injector help
Old 11-17-2017, 12:27 PM
Registered User
Whipple64c10's Avatar
Default Need injector help
I have a 1964 c10 that I have a side mount whipple on. I need new injectors for my 5.3 truck intake that wont raise the fuel rail up. The truck was a 5.3 z vin flex fuel truck. The current injector number is 12580426.
oring to oring is 52mm or 2 inches
overall length is 64.5ish mm or 2 and a half inches.
I need a 42lb or bigger injector. It has the metal square fuel rail that is returnless also. Does anyone have any ideas.
Old 11-17-2017, 12:33 PM
FFDP's Avatar
Wrong size, sorry.
Fuel injector clinic and Injector dynamics also sell drop in injectors with proper data for tuning.
Old 11-17-2017, 12:34 PM
Registered User
Pictures of the situation
Attached Thumbnails Need injector help-20171114_131623.jpg   Need injector help-20171116_194833.jpg   Need injector help-20171116_194818.jpg
Old 11-17-2017, 12:37 PM
Registered User
I also need uscar ev6 injector plug
Old 11-17-2017, 12:38 PM
FFDP's Avatar
Hmm, wait, those are USCAR injector connectors. I may have linked the older ones.
Old 11-17-2017, 12:40 PM
FFDP's Avatar
Here are stock 56lb/hr upgraded replacement injectors.
35U-00-0056-8 - DeatschWerks Fuel Injectors - DeatschWerks
You could call them to confirm exact length or contact another vendor.
You're other options could stock 50lb/hr or 52lb/hr injectors from a GEN 4 6.0 flex fuel truck or 6.2 flex fuel truck. Those are USCAR style injectors.
Old 11-17-2017, 12:47 PM
Registered User
The problem with those is that they are only 48mm I believe I'm hoping someone can chime in and show me pictures. Or guarantee some fit. I'll give them a call still and ask. Thank you.
Old 11-20-2017, 10:16 AM
Registered User
Nobody has put ls2 injectors in there 5.3? Or anything
Old 11-20-2017, 08:12 PM
B00sted2007's Avatar
What you need is any ls2 length Injector and the uscar ev6/ev14 style Injector.... I believe they’re 48mm from o ring to o ring. im gonna recommend some Injector dynamics or any of the other known companies, i personally only buy Injector dynamics, yeah they’re expensive, but they’re dead on with Injector data and I’ve never had a single problem with any I’ve ever purchased!
Whipple64c10 (11-21-2017)
