Need injector advice please....
Old 08-13-2018, 09:50 AM
Registered User
bryanw1968's Avatar
Default Need injector advice please....
Hi,
Does anyone know where I can find a set of 36lb, 43 PSI truck injectors? The short ones I think they're 1.9" long.
I am running a 5.3, TSP 216/220 550/550 lift truck cam, 799 heads, LS6 springs, LS7 lifters, TSP long tube 1 3/4" headers and a single 3" Dynomax exhaust and a tune from Aikman Performance in Cedar Park, TX.
Currently I have stock 21lb injectors and this thing is falling on it's face ;-)
Thanks!
Bryan
Old 08-13-2018, 09:52 AM
FFDP's Avatar
You can buy 8.1 truck injectors that are direct plug and play with your truck. They are rated at 31lb/hr and will flow plenty of fuel for those mods. A very common upgrade guys because the data is a direct swap also from a 8.1 truck tune file.
Old 08-13-2018, 10:46 AM
Registered User
bryanw1968's Avatar
Thanks. And the 8.1 are 1.9" not 2 1/2" right?
Bryan
Old 08-13-2018, 10:50 AM
FFDP's Avatar
Not sure off hand. Even if they were slightly longer all you need is 4 mini spacers of the fuel rail bolts and it works just fine.
Old 08-14-2018, 10:47 AM
domr's Avatar
I found 2010-2013 6.0 flex fuel injectors to be more cost effective (part number 12613412). Combined with connector pigtails to adapt the connector, if necessary. These are 50 lbs/hr at 58 psi and data is readily available from stock tunes. They are 1.9" long.
Old 08-14-2018, 05:42 PM
FFDP's Avatar
Some of the problems people do run into is converting GEN 4 data into a GEN 3 computer that uses different values.
Old 08-14-2018, 07:50 PM
domr's Avatar
I've found the attached spreadsheet useful for converting data.
File Type: xls
Old 08-14-2018, 10:24 PM
100% Redneck
RedXray's Avatar
Received 1,329 Likes on 792 Posts
For those particular 50 lb/hr injectors (12613412) I found the conversion tune file in the Injector sticky over at ls1tech. I also run these flex injectors.
bryanw1968 (08-15-2018)
Old 08-15-2018, 09:28 AM
Registered User
bryanw1968's Avatar
Default Injector spacers and longer bolts.......
I found these. Got them yesterday. I'll let ya'll know how they fit once my injectors show up.
Thanks again for all the advice.
Bryan
Amazon Amazon
lukn4trbl355
08-11-2010 10:19 AM
Curdoghunter
13
01-25-2010 11:52 PM
sickREDsierra
08-11-2008 08:55 AM
BigBlockChev572
03-22-2006 01:15 AM
Quick Reply: Need injector advice please....
