Looking for injectors and an intank pump
Old Jun 8, 2012 | 02:02 AM
Denali08's Avatar
Originally Posted by black4.8
delphi 60# from five o motorsports are plug and play. 340 aeromotive pump is a little better than the walbro 255. jegs sells the 340. bunch of the 255 on ebay, just make sure its a legit walbro.
Do you have 340 aeromotive pump part number for 2003 Chevy Silverado?
Is it direct fit?
Old Jun 9, 2012 | 12:45 PM
black4.8's Avatar
i believe the only difference is the in/out location. not sure which one you would need. someone thats using it could probably give the part #.
Old Jun 13, 2012 | 08:01 AM
Denali08's Avatar
I am on stock fuel pump with 60# injectors pushing 470rwhp. It drops pressure from 58 to 20 psig above 4000rpm.
I have Walbrow 255lph but my tuner is saying don't install it and better get 340.
I have adujtable FP regulator, also.
I am woundering if Walbrow 255lph and 60# injectors will be short for 500rwhp.
Old Jun 13, 2012 | 03:06 PM
black4.8's Avatar
255 will get you to 500hp to the wheels. i got 505rwhp on 255 and 60# inj. pressure only dropped into the high 50's psi. ran it for a 1 1/2 yrs. w/o any problems. wouldn't push it much past that. still running same setup w/ meth now.
Old Jun 22, 2012 | 02:50 PM
Denali08's Avatar
Did you install it with or without wiring kit?
Old Jun 23, 2012 | 05:57 AM
black4.8's Avatar
factory wiring
Old Aug 29, 2012 | 09:34 AM
Choda's Avatar
black4.8 what do you know about the stock flex fuel pump and FPCM VS a 255.
I am shooting for reliable 500 wheel with my 2009 turbo 5.3 and know I need injectors and def pointing toward delphi 60.
Im tempted to get the injectors and see what my tuner can do with the fuel management. If i need a pump then ill get the 340.
This delphi are plug and play right?
5.3Okasai
Mar 9, 2022 01:07 PM
echoman
Aug 22, 2015 01:53 PM
05GMC4.8
Aug 7, 2015 09:55 PM
MS3Z
Jul 30, 2015 06:17 PM
