Holley hi ram
Im having a bit of trouble fiting the ev1 210lb injectors on the holley fuel rails they just wont line up anybody have these problems if you have more in depth questions I can answer them but I had to walk away I was already frstrated help please
Injectors are straight so that doesnt make a lot of sense. Do you mean height wise? You may need 12mm (1/2") spacers to make them longer, not uncommon.
I was once sent ls3 fuel rails with a ls1 hi ram, needless to say they definitely don’t line up. |
Yes fuel rail dont line up to the bolt holes any suggestions
The area where the holes are is solid metal. Depending on which way the holes are off, you can drill new ones. Or send them back and get the right rails.
