Gmt900 Fuel Pump upgrade Questions/Advice
Old Apr 10, 2025 | 06:24 PM
02tahoelt's Avatar
Default Gmt900 Fuel Pump upgrade Questions/Advice
I installed the Aeromotive Phantom Dual intank 450’s. Going with -8an Feed & -6an Return. And a couple other goodies. My question, to power the Main pump are you guys using the (-) trigger from factory harness that plugged into OEM fuel hanger. To trigger a relay to power the fuel pump. I have also read people using Pin #50 (fuel pump relay control) from ECU. But what/how exactly are you using Pin#50 to trigger an external relay to power the fuel pump. If anyone has any info/procedure on this. It would greatly be appreciated.
Old Apr 10, 2025 | 10:25 PM
RDF1's Avatar
DuNnO
5 Year Member
Do you have a FPCM?
Old Apr 11, 2025 | 12:08 AM
02tahoelt's Avatar
Originally Posted by RDF1
Do you have a FPCM?
I do, but am not going to be using the FPCM. Going with a Return style fuel system and fuel pressure regulator.
Old Apr 11, 2025 | 12:21 AM
RDF1's Avatar
DuNnO
5 Year Member
Was just wondering.
There should be a FP output on a E38 since some the early ones didnt have FPCM's.
Have a way to test the output from ECM?
Old Apr 11, 2025 | 01:00 AM
02tahoelt's Avatar
Was just wondering.
X1 Pin# 50 D-GN/WH Fuel Pump Relay Control - Primary
X1 Pin#51 TN Fuel Pump Relay Control - Secondary
Don't know if there is changes to be made, before using this as a trigger, but with key on the Pin #50 has (+) power then goes away. It's a little hard to do troubleshooting, because engine is currently out and i dropped the tank to install the Aeromotive Phantom intank setup.
infiniticrypto
Apr 3, 2025 02:28 PM
bluedream02
Apr 17, 2008 09:19 PM
U LUZ
Aug 4, 2004 12:47 AM
