fuel injector help for H/C/I/E Procharged 6.0
Hello, I currently have the marine 8.1L 42# injectors. Im seeing 63% at 6900 rpm. When I install the procharger Im only going to spin it to about 6500. Where the IDC is about 55. Will I be good if I only run about 8#?
Probably need the multec adapters to run the injector you want. Not sure how much aftermarket multec has, haven't really looked. 60s will be enough fuel for your engine...I don't think that older LQ4 will take more than the 60s can deliver. I ran 50/50 mix with e85 using the 60s and they had just pushed over 90% duty cycle at 20psi and 6200rpm. So they can move quite a bit of fuel.
would these drop in without needing spacers?
Racetronix - L107 - 63 lb/hr Siemens High-Z Fuel Injector MT
I know Ill need to converter the connectors to the EV1 style.
or these
http://www.ebay.com/itm/DeatschWerks...f19866&vxp=mtr
or these
