Fpr regulator for boost?
Hey going return setup on my nnbs truck. Can I run a boosted setup on a c5 return filter and regulator setup? I know I have to reference the injectors for boost but is it possible to do it with that setup and stock rails or do I need a boost reference regulator and aftermarket rails?i have Holley rails but wanted to save for a big project Thanks
You guys have any pics of your set ups or locations? Was thinging near the throttle body but then also I like the look on the firewall but want to run little hose as possible
Resolute_welding (04-24-2019)
I made a bracket and mounted mine off the master cylinder stud. Very clean and easily accessible.
What I’m doing is using an aeromotive FPR for my setup. It’s a tbss intake which is returnless, but the way I have it setup, the stock lines will plug straight into the FPR, and the FPR will plug straight into the fuel rail. I’ll post a pic tonight of it.
