Edelbrock Eforce Injectors wont fit?
Just picked up an Eforce kit for my 08 sierra denali 6.2. I already have some deka tall injectors but they wont fit cause they are too tall. Anyone know where I can get some comparable injectors that will fit?
Also will the stock pump be sufficient?
Thanks
Thanks
I don't know if that kit is similar to the 5.3 kit but with mine you had to run shorty's because of the fuel rail. I run 60 pound deka shortys with adapters. Is your truck stock? I switched my stock fuel pump out for a flex fuel pump.
Okay i will buy some deka shortys from fic. Yes my pump is stock, did you buy the whole new flexfuel bucket? or just swap the pump out? Also I notice in your sig it says your running the flex fuel controller is this necessary and is it just plug and play?
Thanks.
Thanks.
Its the whole new hat and yes to run the flex fuel pump you will need the flex fuel controller and yes it is plug and play. Edelbrock sales it as the fuel supplemental kit, comes with the flex fuel pump/hat and controller. Or buy it separate the one I used is from a 2012 flex fuel.
GXPJAY
Feb 13, 2022 08:15 AM
maxspeed05V
Jul 19, 2015 07:08 PM
