E85 injectors and fuel pump
Guys I’ve read through some posts but nothing hits the nail. I want to run e85 and have gotten 2 opinions at local shops.
450 walbro with 50lb injectors or 255 walbro with 60lb injectors I already have the 255 walbro installed I just want to know if anybody can vouch for the 255 60lb injector combo ? Thanks guys Mods: 6.0 fbo h/c/I |
I'd just get larger injectors.
Getting 50 or 52 lb/hr flex fuel injectors from a newer truck should be all you need. Using FIC's injector calculator, 50's would support 500whp on a NA build and you won't make anything near that on just a heads cam 6.0. |
Originally Posted by FFDP
(Post 5503290)
It should be enough. The other calculator I use says that 450ish horsepower needs around 220-230 LPH on E85.
Most stations never have true E85 either, more like E70ish. I'm from Minnesota too, corn fields and E85 is everywhere pretty much. |
(Post 5503292)
(Post 5503292)
Port injection NA you aren't going to pick up much. DI or boosted- def worth the upgrade
Originally Posted by arthursc2
(Post 5503299)
Using Atomic's spreadsheet, flow of 60lb injectors @80% dc and a Walbro 255 cross at ~55psi yielding ~240l/hr fuel flow. This is only good for ~390hp on E85. Same combo is good for ~550 on gasoline (which is accurate from my experience).
I am of the thought above that E85 is not very beneficial with a mild 6.0 NA setup unless you are running some wild compression (12:1 or higher). |
I only picked up 6 rwhp and 4rwtq on a LS3/TR6060 setup on E75% vs 93oct.
CNC LS3 Heads 227/234 cam Ported/Rodded intake Ported LS3 TB 1-7/8" headers We are going to test it on 250 shot on 93 and on E75 or whatever pump E is at the time. |
