00 Silverado fuel lines
I'm in the process of swapping a 5.3 in place of the 4.3 in my 2000 rcsb. The fuel lines from the donor truck are no good and I'm looking for a solution. I was thinking about just running 6an lines instead of trying to source factory replacements. I know at some point soon I'll turbo the truck and I'll need to upgrade the factory stuff anyway so is there any reason not to go ahead and upgrade now? Can someone please help me get a list together of what I'll need to make this happen? Thanks in advance.
Are these what I need to connect to the factory fuel rails?
https://www.briantooleyracing.com/ls...ing-54028.html
You can use those, but I would use the ones with threaded nuts instead if the plastic clips. A few people had those pop loose under pressure. Here's a link, it's the one that says threaded cap.
Fuel Injected - Adapter Fittings - Russell Performance Products
So I used Google and found this.
https://www.performancetrucks.net/fo...system-535565/
There are course tons of results
Thanks for the info. I wasn't sure if the tank side was the same.
