2 valve 5.4, eaton setup
I'm changing directions on this project
Originally Posted by tarajerame
(Post 4941581)
up for sale is a mostly (98% for a bolt on conversion to a N/A truck or expedition) complete Lightning swap setup:
- originally of off an '02 Lightning - Ported Eaton brand new boost bypass accuator Ported Plenum (ported to clear Magnum Powers "Big O" Stock Throttle Body Ported Midplate intercooler core (stock 10 row) Lightning Alternator (with wiring pigtail) Alternator Bracket stock bosch Intercooler Pump, w/ bracket stock Heat Exchanger with mounting bracket SCT BA 2800 MAF K&N FIPK w/ Amsoil oil free Air filter Throttle Cable (brand new) Throttle Cable Bracket (brand new) Metco 2 piece lower pulley setup (4#) w/ belt (brand new hub and bolts w/ converter lockup tool) stock caged crank pulley Stock Idler bracket and tensioner (rocking an Metco Auxillery Idler bracket) with a 90mm and a 100mm idler attached passenger side PCV line stock Lightning, dual fuel pump, fuel hat (with twin GT-500 fuel pumps) EGR valve EGR Tube (for 3/8 midplate spacer) 3/8 midplate spacer '01-'04 Lightning Engine wiring harness 5 ft of 5/8 heater hose IAT 2 sensor (the screw in one for the turkey pan) you're probably wondering what this setup is missing: brackets for the heat exchanger fuel pump intercooler tank injectors installation tune I'm asking $2500 plus shipping or you pick it up kit is located near Nashville TN the Eaton and Plenum will probably get painted bright silver... now on to the pics http://www.f150online.com/forums/mem...1-dsc00401.jpg http://www.f150online.com/forums/mem...2-dsc00403.jpg http://www.f150online.com/forums/mem...4-dsc00406.jpg http://www.f150online.com/forums/mem...6-dsc00407.jpg http://www.f150online.com/forums/mem...7-dsc00408.jpg http://www.f150online.com/forums/mem...2-dsc00415.jpg |
Man... Too bad i need go fast for my 4.6 2v
Originally Posted by Jimmy_d
(Post 5115154)
:sigh: 4.6 to 5.4 Swap Notes - F150online Forums |
I have an 08 pi 4.6... :(
(Post 5115566)
a two-valve swap is a two valve swap :cody: |
Yeah, at 50k miles it's hard to justify the swap lol
I have a 4.6 built to a 5.0 12.75 lbs of a procharger and alky meth kit on a 2 valve set up and can only get 384 horse and 450 tq at the wheels oh and there are 5.4 heads on there...... these 2 valves just don't make power :deadhorse: I did a lot to this and that's all I can get minus nos.
nice good luck with the sell
