-   Ford Engine & Exhaust Performance (https://www.performancetrucks.net/forums/ford-engine-exhaust-performance-108/)
-   -   First Timer Ford (https://www.performancetrucks.net/forums/ford-engine-exhaust-performance-108/first-timer-ford-424690/)
J$Money Sep 9, 2008 04:19 PM
First Timer Ford
alright as u can prob guess by the title and my sig i'm a chevy guy. well it jus so happens that my gf's a ford lover and she wants a v8 in a ranger(go figure)
:engarde: anyways, im not exactly what you'd call familiar with ford power other than the basics. i'm wanting to keep it fuel injected so she can drive it everyday but i also want it to be strong and give good performance. the power plant decided on was a 5.0 simply because of its ready availability. the tranny decided is an AOD. what cam, compression, stall, heads, etc are suggested for a possible 12 sec motor. i've searched and searched comp, lunati, etc and really no one makes many after market cams for ford.
basically we're tryin to put 2gether a good 12sec setup on motor and a who cares what it runs on bottle because it wont be sprayed often if ever.
ANY help is greatly appreciated
sickREDsierra Sep 9, 2008 04:29 PM
call up trick flow. they have some head/cam combos that on a 5.0 with stock compression could put a ranger in the 12's pretty easily, with the right stall and gears.
also AFR makes some even better heads. a little more, but great heads. look at an e-303 grind cam as well, i had one in a fox body 5.0, and was great streetability with good power.
J$Money Sep 9, 2008 04:31 PM
if im not mistaking that e-303 is a flat tappet am i right?
sickREDsierra Sep 9, 2008 05:17 PM
no sir. roller
http://www.fordracingparts.com/parts...tKeyField=1329
J$Money Sep 9, 2008 05:51 PM
i'm thinking that cam with a GT40 top end should do the trick as far as 12's are concerned
Spoolin Sep 9, 2008 05:52 PM
There is a ford ranger site that is dedicated to V8 swaps...you should check it out. Just google it cuz I forgot what the name of it was. My roomate has a ranger and wanted my old V8 so we looked into it.
Duckslayer08 Sep 9, 2008 09:59 PM
get a 5.0 and stroke it out to 347.should be a mean little truck
J$Money Sep 9, 2008 11:15 PM
stroking a stock block to a 347 is dangerous due to strength issues, kinda like making mad power w/ a 4 bolt main 400 sbc block
sickREDsierra Sep 10, 2008 04:33 PM
gt-40 top with a nice sized cam will go 12's easy, with a 3K+ stall and 4.10 gears.
xchevyx24 Sep 10, 2008 11:26 PM
:punch: put a ls1 in it
