-   FORCED INDUCTION (https://www.performancetrucks.net/forums/forced-induction-159/)
-   -   Wrap vs Ceramic coating (https://www.performancetrucks.net/forums/forced-induction-159/wrap-vs-ceramic-coating-490849/)
scooter k Oct 23, 2011 10:47 AM
Will the Ceramic Coating help keep the underhood temps down just as much as the wrap?
FarmTruc Oct 23, 2011 02:33 PM
No, wrapping is better.
Compare it next time you get a chance, radiant heat is lower with wrapping.
I've tried all the coatings, always went back to wrapping when underhood temps are a concern.
Not that coating doesn't work, it does great.
scooter k Oct 23, 2011 02:58 PM
Is it worth doing both?
02'Z71ONDUBZ' Oct 23, 2011 03:02 PM
Ive got both on mine, I dont think it would really be worth it unless your hot pipes were made of mild steel. It would probably help with corrosion from the wrap in that case.
scooter k Oct 23, 2011 03:16 PM
I have stainless hot pipes except the log manifold
chevyboy.520 Oct 23, 2011 03:21 PM
Id just wrap them with some good wrap, no cheap wrap. I had some cheap wrap come apart within a week. I sealed my DP and turbo manifold with some good wrap, and have had no problems, now on the other hand. My crossover, was wrapped with a cheap brand of wrap, and it came apart.
Alpinestar Oct 23, 2011 03:48 PM
If you decide to go with the wrap just use regular hose clamps to hold the wrap in place. They work a lot better than DEI's wrap ties but just doesn't look as professional. If you do end up going with the DEI ties, I could sell you mine that I didn't use on my hotpipes. :secret2:
sureshot Oct 23, 2011 04:04 PM
Would just having the pipes ceramic coated be enough? Or would wrap still need to be used?
M&M Turbochargers Oct 24, 2011 10:29 AM
i like to use safety wire to hold my wrap on
Secs-10 Oct 25, 2011 10:06 AM
^^ me to. If you've ever done any MX racing and wired your grips on just do the same on the wrap. Works great and ALOT cheaper than the stainless ties
