Wideband reading way off at WOT?
my truck was tuned using a different wideband than the one I have installed, which I was tuned to 11.5 AFR
After plugging my wideband back in and driving off I remember it not reading 11.5, but something lower (like 11.1). Now (months later) when I go WOT, it reads 10.1 I have the aeroforce interceptor wideband kit. I've reset the sensor back to normal and it still reads this. At idle it reads correct (14.6+-) any idea on how I could see if my sensor is bad? Since the tune, I have had problems with my MAF acting up (having to clean it a lot or else it will misfire/idle horrible and some times die while coming to a stop) and also I think I am burning a little oil (not sure if these could effect the AFR) |
Originally Posted by TXjeepTJ
(Post 4860669)
where do you have your 02 bung placed?
sounds like the wideband is correct and your maf is screwing up...
SD tune
Originally Posted by lsx408
(Post 4861277)
tuner is located 8 hours away, so that doesn't help. I guess the common sense thing would be to find someone local with a wide band to see if they would let me hook it up to get a reading SD tune is definitely in my future! I can't stand my MAF |
