i'll see if'n i can find it. i do remember he had one of the first 14rib rear pulleys & had the blower turning well over 20k rpm!
merry christmas! ;)
https://www.corvetteforum.com/forums...ld-thread.html ps - what kind of gains did you see with your spacer? i saw results for the 1" ones in Janetty's camaros & Ray's truck, but headn't seen/heard of enough thinner ones being used. i've only got clearance for 1/2" at best. |
Mine sees 21-22k rpm. The spacer helped with heat soak and some with iat. I don’t there is much to gain with it unless your really working it. I opened up the intercooler openings, Maggie’s stock opening is really small, am running a LPE varimax pump and dual HX. My iats even with the 2.6 pulley only climb 28-30 deg on a 0-110 pull.
If the opportunity pans out I may drop a 2.9 head unit on with nothing else changed and see what the difference is.
Are you and Rob like long lost brothers or something? Lol
Originally Posted by 91LT16SpeedFormula
(Post 5429039)
(Post 5429039)
Originally Posted by Duntov1967
(Post 5428176)
The new production model is a rear inlet (non-jack shaft) on the driver side.
Anyone remember that company's name from the aftermarket J-tubes? |
