-   FORCED INDUCTION (https://www.performancetrucks.net/forums/forced-induction-159/)
-   -   What stall converter for turbo (https://www.performancetrucks.net/forums/forced-induction-159/what-stall-converter-turbo-530348/)
TurboNgo Jun 26, 2014 10:51 AM
I have a 2001 z71 single cab with a 6.0 with isky triple 12 cam ported heads 373 gears gota s480 t6 turbo on e85 planning on about 800hp I want the yank triple disk converter. I'm going to be launching in 4 hi also but I don't know which stall to get. 2800 3400 or 3600. Any thoughts? Thanks
Vortec350ss Jun 26, 2014 11:39 AM
With that much power I'd lean toward the 2800 over the 3200.
Denali08 Jun 27, 2014 09:15 AM
Check my signature. Almost same goal and this is what yank recommended. It runs great. I think 2800 will be little bit low but you have 6.0L and I have 5.7L.:D
Atomic Jun 27, 2014 12:17 PM
As tight as possible will be the fastest, but will spool slightly slower than a looser one.
black00chev Jun 27, 2014 03:13 PM
I'd go 2800 cause It will probably run more towards 3000 depending how much power you're making.
TurboNgo Jun 27, 2014 04:00 PM
Thanks for the input guys. I'm just wondering if 2800 will be enough to spool the turbo up decently quick. No converter expert by no means so thanks for your input
GMCtrk Jun 27, 2014 05:23 PM
I'd go with the 3200.
oakley6575 Jun 27, 2014 05:44 PM
Same. I think the 80mm will want some rpm to get going. I personally like a tight converter but that is up to the user. If it were me I'd go with a 258mm 3200
AKlowriderZ71 Jun 27, 2014 06:12 PM
3200 all day every day.
Razor Jun 27, 2014 09:30 PM
SC3000 in my junk. 608rwhp/672rwtq...10.6 @129 so far.
Call them and ask.
