What size intercooler?
Old Jul 20, 2011 | 06:41 PM
cfaluck13's Avatar
Default What size intercooler?
I only measured 26" from frame rail to frame rail.
But then I saw KB uses a 27" intercooler i believe?
What sizes you all using?
Old Jul 25, 2011 | 08:24 PM
cfaluck13's Avatar
no input
Old Jul 25, 2011 | 09:06 PM
black04's Avatar
KB uses a 27x12x3" intercooler if you want to mount it between the frame rails
TrickTurbo's Avatar
Truck Sponsor
If you have a KB kit then going with his IC you should have no problems with the install. IC measurements are usually at the widest point. And the tanks are tapered, so were it goes in between your frame should be fine.
Give kyle a call or pm.
Old Jul 26, 2011 | 05:46 AM
foose04's Avatar
Here's my first hand data on frame mounted intercoolers, worth a read.
https://www.performancetrucks.net/fo...c-bolt-477769/
GMCtrk
Oct 20, 2015 06:17 AM
Superman09
Sep 25, 2015 05:55 AM
Closer_2001
Sep 24, 2015 09:15 PM
TrickTurbo
Sep 23, 2015 08:41 PM
