what the best spark plugs for boost?
any suggestions?
TR-6 gapped at .035
Ngk BR7EFS .035 gap after countless hours or research, its a colder plug than the Tr6 which means safer plug
with no information on the setup how can you recommend a plug ?
we need to have a sticky with plug numbers / boost and nitrous levels like on tech . this questions is asked way too often. |
Originally Posted by 2004SSS
(Post 4657089)
we should make the search button larger.
oh shit here we go . i posted a similar one earlier .
someone make this a dam sticky LS1 Stock and AFR Thread – 14mm Reach - .708” Socket – 5/8 hex Seat - Taper Stock Heat Range: 5 Gap: .060 Plug: NGK TR55 (stock number 3951); NGK TR55IX (stock number 7164); Autolite 764; Denso IT-16 (stock number 5325) Nitrous (one step colder) Heat Range: 6 Gap: .035 - .038 Plug: NGK TR6 (stock number 4177); NGK TR6IX (stock number 3689); Autolite 103; Denso IT-20 (stock number 5326) Nitrous (two steps colder) Heat Range: 7 Gap: Consult Plug: NGK BR7EF (stock number 3346); NGK TR7IX (stock number 3690); Autolite AR94; Denso IT22 (stock number 5327) Nitrous (two and a half steps colder) Heat Range: 8 Gap: Consult Plug: NGK R5724-8 (stock number 7317); NGK TR8IX (part number 3691); Denso IT-24 (stock number 5328) Nitrous (three steps colder) Heat Range: 9 Gap: Consult Plug: NGK R5724-9 (stock number 7891); Autolite AR93; Denso IT-27 Nitrous (four steps colder) Heat Range: 10 Gap: Consult Plug: NGK R5724-10 (stock number 7993); Autolite AR92 LS1 w/ Edelbrock and Dart Heads Thread – 14mm Reach – 3/4” Socket – 5/8 hex Seat – Gasket Stock – MFG Recommendations: approx under 9:1 compression Heat Range: 4 Gap: Consult ignition mfg. Plug: NGK FR4 (stock number 5155); NGK BKR5EIX (stock number 6341); Autolite 3926; Champion RC12YC (stock number 71); Denso IK16 (stock number 5303) MFG Recommendations: approx 10.5:1 compression Heat Range: 5 Gap: Consult ignition mfg. Plug: NGK FR5 (stock number 7373); Autolite AR3924 (Racing Plug); Autolite 3924; Champion RC9YC (stock number 2075); Denso K20PR-U (stock number 3145); Denso IK20 (stock number 5304) MFG Recommendations: approx 11:1 compression Heat Range: 8 Gap: Consult ignition mfg. Plug: NGK R5672A-8 (stock number 7173); Autolite AR3911; Champion C63YC (stock number 796); Denso IQ24 (stock number 5314) MFG Recommendations: approx 12:1 compression Heat Range: 9 Gap: Consult ignition mfg. Plug: NGK R5672A-9 (stock number 7405); Autolite AR3910; Champion C61YC (stock number 785); Denso IQ27 (stock number 5315) MFG Recommendations: approx 13:1 compression Heat Range: 9 - 10 Gap: Consult ignition mfg. Plug: NGK R5671A-9 (stock number 5238); Autolite AR3933; Champion C59CX (stock number 296); Denso IK27 (stock number 5312) MFG Recommendations: approx 14:1 compression Heat Range: 10 Gap: Consult ignition mfg. Plug: NGK R5671A-10 (stock number 5820); Autolite AR3932; Champion C57CX (stock number 295); Denso IK-31 (stock number 5321) **NOTE: Use chart for static compression and adjust heat range for nitrous use accordingly. >600 hp - 6 heat range >800 hp - 7 heat range >1000hp - 8 heat range from what i have read this is close but if someone with experience would please chime in to get that info based on facts it would be nice. |
Now what about boost lol... say 8lbs
ngk tr6
0-12lbs, ngk6
12-18lbs, ngk7 18+, ngk 8 |
