wastgate ??
Old Oct 16, 2007 | 06:50 PM
Slowhawk's Avatar
LS1Tech Sponsor
Originally Posted by 05crew
can u have to big of a wastgate? i think mine is a 38mm, might not be 38mm is in my head.
38mm is still on the small side.
Old Oct 16, 2007 | 10:19 PM
05crew's Avatar
so i should plug the hole on the turbo to the wastgate, take that line off and run a boost line form the wastgate to the intake and tee in to my line that my boost guage is on, if that dont work by a 50mm wastgate!!! thats what im geting from this?
thanks for all the help!! i need to get this fix ASAP?
Old Oct 17, 2007 | 12:45 PM
alanderson1978's Avatar
That wil do it!!
Good luck!
Old Oct 17, 2007 | 06:18 PM
05crew's Avatar
what about the hole on the wastgate? how do u plug it, just a bolt i understand to plug the hole on the turbo, just do the same on the wastgate? ****.....this stuff is new to me
alanderson1978 thanks for the help and info to all!!! ill get it one day!
Old Oct 18, 2007 | 10:26 PM
If you're using the Tial wastegate that STS sells, it has 2 ports on it. The bottom side (closer to the poppet) would run to the intake manifold. The top one needs to be left vented, or the wastegate will not open when it should.
I'm learning this stuff right now too.
HTH
02chevyls1
Jul 1, 2015 08:52 PM
bigboy576103
May 26, 2015 07:30 PM
bigboy576103
May 15, 2015 10:16 AM
BUTTERB30
Jan 4, 2015 04:27 PM
59fordcummins
Aug 3, 2013 04:55 PM
