WARNING to Bosch 044 owners
Just a little heads up to guys running Bosch 044 pumps on stock wires. This past week, sharpshooter and I rewired our pumps using 10 gauge wire and 40 amp relays. When we dropped sharpshooter's tank, the stock power wire was melted pretty bad. It was also causing other wires near it to melt. If the wire got hot enough to melt the coating, I don't know how much more it would have took to ignite the gas in the tank. We bought pump rewiring kits from Jayracing. They come with really high quality 10 gauge wires, a 40 amp relay, 14 gauge wire for grounding the relay, a fused power wire for the relay, wire ties, and various connectors. Again, just a heads up to those of you who may be running these pumps on stock wiring.
I'm glad I did mine to begin with, because with my luck it would have burnt my truck to the ground. That wiring kit is good quality though, and that's the only place I could find the check valve for that pump.
Originally Posted by brent1976
(Post 4488043)
wow that is definatly scary..
No ? Bout it the gas would've ignited had there been enough o2.
In all honesty people should always run the correct gauge wire when installing a more powerful pump.I to learned in the same manner. |
Originally Posted by SincalT/A
(Post 4488132)
How much boost are you making with the 3.6" pulley now?
Originally Posted by gao8302
(Post 4488183)
What about a walbro pump? Would one need to upgrade the wiring for that one as well? Just wondering, as ill be installing one very soon when I do the TVS install.
Wow, thanks for the heads up.
| All times are GMT -5. The time now is 04:10 AM. |
